Hotcarl was kind enough to send me a design someone had made up for him for a SS RL-i 8. I wanted to see if you guys could take a look at it for me and see what you think. I personally have never designed or built a TL. Not to mention I will not have time to build this any time soon, so don't ask for progress pictures
  • Replies 55
  • Views 8.3k
hmmm, you could use a straight line and not have to deal with angles. there are diffrences but i don't know much about tls. check the decware forum. there is a pretty good discussion on tls on the ht forum. and a lot of smart guys.
maybe they can help with a design.
just looking at it kinda reminds me of nolte's snailshell.
i might build this and drop my rl-i8 into it...put it in the boy's room....
or the TB....
yeah, i think i will do this...
wheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee :slayer:
If someone makes it and really likes it i'll make one as well.
For now its just sealed with a 10" PR
is it just me or does it look like a rather simple TL design...?
which is exactly why i want to build this one..lol..
and will this weekend...
wheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee :slayer:
i believe mountaineerman over at caraudio.com does a lot of TL's and everyone has had success with his designs.
I believe this is sourced from him.
better keep us posted! :OhYeah:
Edited by joebangaa
i am going to, i promise..lol...
gimme time...sheesh..lol...
wheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee :slayer:
i built it, i built it..yes i did, i built it!!
anyway..i get a pic or two, and a vid...
going to test it h2h against the sealed enclosure (.17ft^3) in the room and then throw a meter on it in car...see what it does against a 12" hehe
anyone want the leftovers??
wheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee :slayer:
testing to commence in a few hours...
wooowhooo!!
wheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee :slayer:
ok...just got done in room..
source unit is a jvc hx-z1 delivering 110 watts of power to the subwoofer via a seperate subwoofer output (rated 120 x 2 for the highs, 55 x 2 for the subs) that's regulated for anywhere from 6-16 ohm...teh rl-i is wired for 8...
both enclosures will be placed facing the wall, 4" away. the mic is 6' away, about 1' below the sub.
first up is the recommended .17ft^3 sealed endeavor. and i'll tell ya, the rl-i performs in this thing. blends nicely with the rest of the system (7" dayton alum mids, hifi 1" textile dome tweeters,using memphis mclass xovers, in .66ft^3 tuned to 55hz IIRC, i'll have to look that up around here.) and delivers awesome bass response. it peaked at 104.5db@ ~ 50hz, not bad for 110watts.
the transmission line, well, wow. at 32-35hz this thing delivers around 110db. talk about lowend reenforcement..lol... and averages around 106-108 for the rest of the range i played it.but it also blends better with the rest of the system then the sealed one did. i believe it's because the selaed one is overpowered a bit by the fact the highs are getting 240 watts compared to it's 110. the tl keeps up and even mnakes the tweeters appear to be not as bright. again, i think this is due to the power level.
next up...
the rl-i8 in tl vs the la strike in basic ported in the tb!!
the la will have a power advantage, i'll be using an orion 2500d and the la is wired for 4 ohms. the rl-i for 8.....
and off we go!!!!
pics later...
wheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee :slayer:
part one of in car testing done!! and i've gotta say, so far so great!
first test was the lightning audio strike x2 12" in 2.5ft^3 tuned to 28hz. the best i could do with this set up (again, orion 2500d wired at 4 ohms) was a 130.5 @ 45hz, every try was legal, mic on dash, truck off, sealed up car. (if you remember, same box, same amp and same power as it was ~ 4ohm as well, the rl-s sub, did a 136.6 @ 34hz). musiclly, this sub does a good job in this application. no real complaints here.
second test...removed the la and box, dropped in the rl-i and the tl, same settings on everything, except it's wired tp the orion at 8 ohm and it breaks out a 128.7@ 41hz! half the power, and half the cone area and it damn near equals the LA! at a lower frequency! tweak the amp a bit, and boom, 129.9 @ 42hz! play it outlaw for giggles..132.7@41hz!
so i know the tl is loud (we already knew the rl-i was capable..lol) for what power it's getting. now it's time for music! i'll report back on this one as it'll stay in the tb for a couple of days......
again, factory electrical system, factory headunit, all scores legal save the one noted, on a tl.
Hrmmm....
Why must you make me build this !!!!
Do you have a simple ported enclosure for it to see how much louder/quieter the TL is
Hrmmm....
i might actually sell this one..hence why it's not carpeted..lol..
but no, i don't have a simple ported box. but i think one is definitely in the future. like you, i have to know what the difference is...
wheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee :slayer:
