Posted July 18, 200718 yr i have two assasin 8`s in a sealed box . what kind of amp would u recomend? fosgate 600.1 d or something. thank for any info.
July 18, 200718 yr Anything in the 400-600 W range should work well for them. A little harder to find a 2 Ohm mono amp though.
July 18, 200718 yr i have two assasin 8`s in a sealed box . what kind of amp would u recomend? fosgate 600.1 d or something. thank for any info.Do you know what mounting depth of your 8" AA Assasins are? I'd recommend Arc audio amps. The new line-up is sexay.
July 18, 200718 yr I'm thinking about getting an Assasin if it meets these requirements for fitting into the stock subwoofer enclosure in a Ford Expedition:And the spec requirements are:# 8" 4-ohm subwoofer# top-mount depth: 3-3/4" (most important)
July 21, 200718 yr I'm thinking about getting an Assasin if it meets these requirements for fitting into the stock subwoofer enclosure in a Ford Expedition:And the spec requirements are:# 8" 4-ohm subwoofer# top-mount depth: 3-3/4" (most important)Not even remotely close. The Expy uses the same subwoofer as my Mustang, and it maxes at about 3.6". It's been a real burden to get the performance in that shallow space. Maybe someone could make something worthy? (hint, hint, Scott, Chad-coughcough).
