Posted July 20, 200718 yr I am purchasing a sundown sae1000d and was wanting to run a 12 fi Q, which one would i need to get the dual 2 ohm or dual 1 ohm? I want to get the most power out of this amp and not sure which one is better for that? thanks
July 20, 200718 yr One sub get the dual 2 ohm so you can get a 1 ohm load on the amp and get full rated power within warranty of the amp....
July 20, 200718 yr Author One sub get the dual 2 ohm so you can get a 1 ohm load on the amp and get full rated power within warranty of the amp....so with dual 2 i will be at one ohm and cover the warranty of the amp? sounds good, hoping the sae1000D makes the q sound good, think thats enough amp for the job?
