ok i got a few questions: 1, i need help choosing a sub amp here is what i am thinking:
us amps XT-4000D
used us amps md1d
Used ED 9.1
used/refurb kicker sx1250
Hifonics TXi1508D
i am trying to not spend more then 300 on the amp and i need 1200rms at 1 ohm.
Another question is this: on my car it is a single wire running for the alternator and the way it is suppose to be wired that it came with a 6" long run of 10 guage wire attached to the alternator to a point where then i have 1/0 guage running to the battery. could that 10 guage wire pose a voltage problem for 200 amps.
And the last question.
i am thinking of using kinetic batteries and they to use a hc1400 under the hood and a hc2400 as a second battery. well this is how i think i want to wire it but i want to make sure that it won't cause any problems.
ok, the hc1400 will be set up normal besides that i need to change my side mount terminals to be able to use top mount posted one. and then i already have a 1/0 guage run into a distrobution block then from the distrobution block it goes to 4 guage wire to the amps. now my distrobution block has a 1/0 input 1/0 output and 4 4 guage outlet ( it is the distrobution block that comes with the 1/0 guage kicker duel amp kit) and i am wondering if i could connect the hc2400 postive terminal run to the distrobution block and do the same thing for the ground.
oh and sorry for the long post.
