There are a ton of options. We would first need to know which voice coil configuration you went with.
Looks like any amp that will do between 2000 and 2500 at 2 ohms. Kicker ZX2500 would be a good option. You could also do a pair of 1000's provided they are both 1ohm stable. If you wanted to stick with Diamond, a pair D6 1200.1's would do it.
wel i was thinking on getting one amp for 2 subs and then another amp for the other two...
maybe this???
http://cardiscountstereos.com/catalog%20pa...duct+%23=A8000V
and maybe run it a certain way??
maybe this???
Two of those won't work. And they would be under powering those subs. If you go with a single amp, it will need to be 2ohm stable, if you go with a pair of amps, each will have to be 1ohm stable. The subs are dual 4 ohm subs, so you have to be selective about your amps.
  • Admin
:WELCOME:
ya all thos amps you sugjested would work great but i realy need to stay under 250...
maybe this
http://www.onlinecarstereo.com/CarAudio/Pr...ProductID=16338
Yes, two of those will work. I stress to you that you will be under powering them with this choice though. Roughly half of RMS. I totally understand the budget constraint though. Maybe you should go with 2 of them for now until you can properly power all four? just a suggestion though.
And because I missed it, Welcome! It is good to have you here. :)
maybe this
ok well im probbably just going to get all four and just put two in my car for now, but then what would be a good amp?
Something that will do between 1200 and 1500 watts at 1ohm. See if you can find one used here or on other car audio forums. When you are ready to upgrade. Just buy another amp and add the other two subs. :)
Edited by Chris
