Posted July 29, 200719 yr I was talkin to a box builder last night...He gave me some good advice.My main goal is a LSQ system...He said go with a FI Q 18...i was like have you heard one...he said yeah...in a sealed box. He said it would sound better than the same woofer in a ported. This is what he relayed to me from an installer friend of his. I was like ok... He said go 18 inch Q sealed 4 cu ft.....i was like how bout 7 cu. ft ported tuned to 30 hz...I was thinking would it make a BIG NOTICABLE differance on an 18 inch Q...in those box dimensions...its an 18inch sub...thats pretty big...or should i go with the 15...?(for LSQ)
August 1, 200719 yr I was talkin to a box builder last night...He gave me some good advice.My main goal is a LSQ system...He said go with a FI Q 18...i was like have you heard one...he said yeah...in a sealed box. He said it would sound better than the same woofer in a ported. This is what he relayed to me from an installer friend of his. I was like ok... He said go 18 inch Q sealed 4 cu ft.....i was like how bout 7 cu. ft ported tuned to 30 hz...I was thinking would it make a BIG NOTICABLE differance on an 18 inch Q...in those box dimensions...its an 18inch sub...thats pretty big...PORTED FOR ME HAS ALWAYS BEEN THE WAY TO GO. YOUR SUB, YOUR CHOICE!or should i go with the 15...?(for LSQ)
August 1, 200718 yr lol... that is exactly what I drive Im a big fan of sealed for clean/SQ oriented applications. But I have noticed that most people tend to favor the bloated bottom end of a ported enclosure. If output is a concern, ported will get you there with a larger box. Sealed will have a more natural response curve when cabin gain is factored in and will still be loud overall... just not as "fat" around tuning like a ported enclosure.
August 1, 200718 yr Author lol... that is exactly what I drive Im a big fan of sealed for clean/SQ oriented applications. But I have noticed that most people tend to favor the bloated bottom end of a ported enclosure. If output is a concern, ported will get you there with a larger box. Sealed will have a more natural response curve when cabin gain is factored in and will still be loud overall... just not as "fat" around tuning like a ported enclosure.The ported box...will have a boost in output...only at the tunning frequency correct? And the sealed box will be flat all around.So basically I will still get pretty loud...Im not tryin to go to comps and all that..I jus wanna sound good...but when i get loud...make it be clean!
August 2, 200718 yr At 7 cuft tuned to 28 Hz (I pushed it a little lower to flattne the response a little more) you will be about 4 dB up on the sealed enclosure. 4+ at 40, 2.5 at 50 and 2 at 60... about even at 70. The ported enclosure will definitely be louder, but itll have a bass hump in the 30-60 range vs a relatively flat and more natural response from sealed.Thanks,Scott
August 2, 200718 yr At 7 cuft tuned to 28 Hz (I pushed it a little lower to flattne the response a little more) you will be about 4 dB up on the sealed enclosure. 4+ at 40, 2.5 at 50 and 2 at 60... about even at 70. The ported enclosure will definitely be louder, but itll have a bass hump in the 30-60 range vs a relatively flat and more natural response from sealed.Thanks,ScottWhat would it be @30hz & down?
August 3, 200718 yr At 7 cuft tuned to 28 Hz (I pushed it a little lower to flattne the response a little more) you will be about 4 dB up on the sealed enclosure. 4+ at 40, 2.5 at 50 and 2 at 60... about even at 70. The ported enclosure will definitely be louder, but itll have a bass hump in the 30-60 range vs a relatively flat and more natural response from sealed.Thanks,ScottWhat would it be @30hz & down?I was going to answer that but I will shut up.
