Posted July 30, 200719 yr hey scott or nick or anyone that knows..when ordering a sub is it possible to have the terminals on the sub swapped out with ones that have a bigger hole to fit a larger gauge of wire? cuz i wanted to use 8 gauge on my Q but it wont fit on the sub
July 30, 200719 yr strip some of the wire back. Surely you aren't sending enough power to the Q to warrent 8awg cable.And if you are... bye bye warrranty.
July 31, 200719 yr Sorry... I dont have any. But I normally just cut back about 20% of the wire and twist. There is no loss in doing so as it is only over 1/2" of length
August 6, 200719 yr I have 8 guage run to my Q and i dont have problems with it fitting in the terminals
August 8, 200719 yr +1...knukonceptz 8 ga fits with no problems. The tork-lite terminals are starting to grow on me.
August 10, 200718 yr I feel so left out with my 16 gauge wire, I'll need someone to track down my deebeez for me.
August 11, 200718 yr Yes they are. They fit the "smaller" 8awg with a good twist to them, but some of the "bigger" 8s you will need to trim a little off the OD.
August 11, 200718 yr Just get a cigar trimmer and roll it around slowly until it fits in, either that or be smart and just buy a size wire that makes sense as 8 is stupid overkill and this of course is coming from the king of overkill.
