If u get the full cooling option on the btls does that include the pole piece venting also as well as the side venting. Or is it just the side venting and the pole piece is covered?
  • 2 weeks later...
I am pretty sure there is not a "pole vent" in the bottom cap with any of the options, and the side vents are always there.
Here is what the cooling options are:
P Chamfer: This is a chamfer on the end of the pole, it helps to bring the air down around inside of the motor and helps cool the coil better. It also helps relieve the pressure underneath the dustcap. We recommend at the bare minimum to get this option if you choose this series of woofers.
Cooling: Self explanatory, the cooling channels are machined into the inside of the sub to help cool the coil FAR better. But there are some things that you sacrifice. There is less metal inside of the motor so it is a little weaker. If you are looking for a fart/burp only scenario for SPL we suggest that you do NOT get this option. Stick with only the P chamfer. Now if you are looking for a daily sub to beat on and you have 2000+ watts the BTL series is for you.
The Cooling option INCLUDES the P Chamfer.
