Posted August 4, 200718 yr I had to move the Vifa tweets up higher to get them more on axis, so I was stuck with a big hole in my new door pods. No way I was doing them again, so I came up with a pretty simple idea that looks pretty decent. More importantly the sound is WAY better now, which was the #1 goal.Pass side tweeter in it's new home. Whipped up some simple PVC angle mounts wrapped in gray carpet. $1.50 and about 30 minutes of time. Hard to make a large format tweeter look "good" in a car, but this will have to do. Close up of the driver's side panel. Fire up the "bat signal" and the caped crusader of midrange appears!!!Went with the blue theme to match my old eXcelon. Takes about 5 mintues for the blue controls to fully light up.
August 6, 200718 yr Very nice work. Did you have to cut the doors some to allow for the depth of those mids? I'm redoing mine too and I can probably fit two mids on each side like yours but I would need to remove some more metal.
August 7, 200718 yr Author Front mid is over the stock hole, but the back one required me to open up a 4" square. About 5 minutes with an air nibbler. I like the logo because it's easy to duplicate...
August 7, 200718 yr Author Now that the tweeters are up higher and on-axis the whole soundstage just came alive. I'm quite happy with how it sounds now. Although I'd love some of the carbon fiber mids since they show. Maybe if they ever release them again.
August 7, 200718 yr I like the logo because it's easy to duplicate...i remember when chad had the contest for the logo and he showed the finalists. . . i wasn't really digging any of the choices they the were looking at
