Posted August 5, 200718 yr I was looking at the enclosure recommendations for the Rlp-18 and I was wondering, If I had enough room for an enclosure that was 26'^3 for a pair of rlp-18's would it be to big for the subs? What would the response be like I want it loud, with an 18 I know it will get low. with an enclosure that large where should it be tuned, around 30hz or lower? Edited August 5, 200718 yr by 300gte
August 10, 200718 yr 26 cu ft between a pair of RL-p18's... Well with that amount of space I am tending to believe that this is intended for home audio, and so I would suggest sharing the chamber and tuning to around 18.5 Hz. For in-car use, by all means tune higher to around 27 Hz, but geez man you certainly don't need that large of an enclosure in the mobile audio environment! Then again... sometimes it's not about what one needs!
