Posted August 6, 200719 yr im working on a box for two mj18s and have a few questionswhat size of port do i need for a box 4.5cf tune to 30hz?would there be a big dif if the box was 4 cf instead of 4.5? ( my box is 9.36cf)any building ideals or stats or thoughts would be greatthanks roddy
August 6, 200719 yr im working on a box for two mj18s and have a few questionswhat size of port do i need for a box 4.5cf tune to 30hz?would there be a big dif if the box was 4 cf instead of 4.5? ( my box is 9.36cf)any building ideals or stats or thoughts would be greatthanks roddyHome or Auto, if home about how many sq feet of the room, if Auto what kind of car/truck/suv and year? Is your box size 9.36cf or 4.5cf?
August 6, 200719 yr Author 2001 exploder suv box size about 9.36 with out any bracing or port or sub i was told to use 1 box with both driversbut i think 1 box with 2 separate areas would be better
August 6, 200719 yr I disagree on the one box with separate areas. It is nice to have a bit of "averaging" when using dual drivers and the only real way to do this is to put them in the same enclosure. Of course an enclosure that is 9.4 cuft needs a ton of bracing.As to your question, yes there will be a big difference between 4cuft and 4.5cuft. Have you already built the box? Normally I account for port length and size before figuring out the total volume of the box, it makes it much easier.
August 6, 200719 yr 2001 exploder suv box size about 9.36 with out any bracing or port or sub i was told to use 1 box with both driversbut i think 1 box with 2 separate areas would be betterI agree With ///M5, one box for the too MJ-18s would sound a lot better, each driver is about .25 cf, what are the measurements of the box? I have put 2 MJ-18s in a 2003 Trail Blazer with a box that was around 10.0cf tuned to 32hz, and about 800 watts going to each one and they sounded amazing.
August 6, 200719 yr Author so with bracing and no sub my volume of the box is16517.187inches cubedwhat do you think i should tune it to?i was told to tune it to 43 hz for most spl but i think 30 hz would sound betterwhat size of port should i use? the box is like t shape and theinside is 38" wideany help would be great
August 7, 200719 yr so with bracing and no sub my volume of the box is16517.187inches cubedwhat do you think i should tune it to?i was told to tune it to 43 hz for most spl but i think 30 hz would sound betterwhat size of port should i use? the box is like t shape and theinside is 38" wideany help would be greatAre you going for spl or daily driving, if spl then about 40-47hz sounds good but if daily you want to go around 30-35hz30hz=about 130 in345hz=about 255 in3 Edited August 7, 200719 yr by turtles1118
