I'm guessing you already thought of this.. but what Ohm MJ's did you get? 8 or 4?
I got 2 4 ohm 18's
  • Replies 68
  • Views 10k
Well I started the box today . Took a few picks
Got a few sides together . Box is going to be 10 cubes tuned to 35 hz.
Another side on . It's gonna be heavy
Got the port in . It's going to have 138 in. of port for the 2 18's
Threw a little black paint in the port
Some 2x3's for lots of bracing . I just have to cut out the baffles and finish all the bracing . I should get the other 18 from UPS tomorrow and can finish most of it . Then I'll just have to carpet the big ba$tard . I'll post some more pictures tomorrow .
Did some more work today. More pictures
A few pieces of bracing
Alittle more
Baffle 1 without the holes
Second baffle with the holes drawn up for flush mount...just need to cut that I'll do tomorrow
A pictures of one of the mj-18's
I should have the woofers mounted and ready to go tomorrow . I'll post more pictures
just make the howl 16 1/2" not 18"
Yeah I got the cardboard circle template with the woofers
how W/D/L is that box?
44in. wide x 36in. deep x 17in. high
It will be laying down in an explorer firing up
Are you sure you have enough bracing in there? ;)
Not quite enough yet :D . 2 more pieces under the double baffle to the bottom of the box up and down .
  • Admin
Looking good, this made the newsletter. :)
mines like 12.5 cu ft for 2 MJ's. tuned to 35hz. giving them about 680 rms each
Sweet... how does it sound ? The box i'm building now started out at 12.5 cu ft . After bracing...port...and subs it's 10 cu ft .
I need to fix a few more cars today then i'll get back to working on the enclousure .
  • Admin
Cool...can you send me one ?
It went to all the members, check your spam box just incase.
Yeah...it's there just checked it out . :woot:
Worked on it a little more today. Cut out the 4 holes and got the front baffle on .
Pics :
A look to see what it looks like with some holes
Put some glue down to attach the other baffle
Almost done . Just have to mount and wire up the woofers
Oh yeah need to put some black carpet on also . Should be done tomorrow
Edited by 82cutty
Did a little of the carpet today . I would have finished but I got a defective can of glue...wouldn't spray .
I guess i'll finish it up tomorrow .
Today got the woofers wired up and mounted . Still need to finish the carpeting though
