Posted August 9, 200718 yr Hello all. I'm getting ready to purchase a Fi Q 12 and a Candence TXA-1000d amp and I was wondering what the optimum enclosure would be for my application. I drive a 97 2dr Exploder, and listen to rock/metal.......lotso heavy stuff. I want the sub to sound as clear as possible when hitting the bass lines and bass drum and still have a nice thump too. So, if anyone has any ideas for specs for me that would be frickin' fantastic!Thanks,Mo
August 9, 200718 yr Sticky link....http://www.soundsolutionsaudio.com/forum/i...?showtopic=7156 Edited August 9, 200718 yr by strong*I*bumpin
August 9, 200718 yr Author Sticky link....http://www.soundsolutionsaudio.com/forum/i...?showtopic=7156Thanks dude, that helps alot!!Is that 1.0 ft3 after sub displacement or before?What would the dimensions of each panel be? Edited August 9, 200718 yr by smokinmo
August 9, 200718 yr http://www.reaudio.com/speaker_box/LPort_Box_Calc.htmlIf you're using a sealed box enter ''0'' for the port requirements.Cut sheets on the bottom Edited August 9, 200718 yr by Earthman
August 9, 200718 yr Author http://www.reaudio.com/speaker_box/LPort_Box_Calc.html"If you're using a sealed box enter ''0'' for the port requirements.Cut sheets on the bottomSorry bud but I think ur links busted
