Posted August 10, 200719 yr This is my first box. I just wanted to know what everyone thought about it. It will be made of 3/4 MDF and its for a 15" FI Q. Its tuned to 29hz, and is about 4.5cuft. I have a crude drawing below. Just tell what you think. Thanks.
August 10, 200719 yr it looks good...i would put a brace in the middle of the port so the bottom peice of wood dont flex80
August 10, 200719 yr looks good i just built my first box not the best but it was my first time really getting into wood work it flexeswish i would hae put a brace in mine take the advice but should be a good desing
August 10, 200719 yr A simple stringer across the port will help or even a 2X4 from the front baffle to the port board as centered as you can get it. Design looks fine as does the size and tuning.Thanks,Scott
