Posted August 18, 200719 yr im lookin into buyin an 15" or 18" FI BL subwooferand ive been intrested in these 2 ampsmy question is what amp would be a better choice for the sub??thanks
August 18, 200719 yr im lookin into buyin an 15" or 18" FI BL subwooferand ive been intrested in these 2 ampsmy question is what amp would be a better choice for the sub??thanksPersonally, I'd have to go with the Rockford. The power series are some good amps. They are also underrated.
August 19, 200719 yr Admin If you get a D1 sub, then the Kicker, if you get the D2 sub then the RF. I believe the Kicker will do close to 1700, where as the RF does about 1400-1500.
August 19, 200719 yr Author If you get a D1 sub, then the Kicker, if you get the D2 sub then the RF. I believe the Kicker will do close to 1700, where as the RF does about 1400-1500.if i got the RF, wat options should i get, cuz i already know if i got the kicker i would get all options besides the the extreme leadsso maybe only cooling (p chamfer included)
August 19, 200719 yr Admin If you get a D1 sub, then the Kicker, if you get the D2 sub then the RF. I believe the Kicker will do close to 1700, where as the RF does about 1400-1500.if i got the RF, wat options should i get, cuz i already know if i got the kicker i would get all options besides the the extreme leadsso maybe only cooling (p chamfer included)The RF is a sweet amp for sure. If you went that route, I would just go flat wound, maybe pchamfer.
August 23, 200719 yr If you get a D1 sub, then the Kicker, if you get the D2 sub then the RF. I believe the Kicker will do close to 1700, where as the RF does about 1400-1500.i have heard of some of the RF's comin in as high as 1800 Edited August 23, 200719 yr by defj
August 23, 200719 yr with the kicker doing rated at 2 ohms thermal power handling won't be quite as much of an issue.i'd get the zx, pole chamfer, and flatwind.
August 23, 200719 yr Author with the kicker doing rated at 2 ohms thermal power handling won't be quite as much of an issue.i'd get the zx, pole chamfer, and flatwind.no cooling? dosent Fi recommend it for daily??
