Posted August 21, 200718 yr so my bro has a reg cab ford f150 and he wants a fully loaded btl 12 ran off a rockford 30001bd amp 1/0 wire 2 kinetics excessive amperage alt. what do you guys think.. he also said moneys not a problem.. so yeah..
August 21, 200718 yr Ya..... Not really sure what you are wanting to know. Like whether or not its a good setup or what?
August 22, 200718 yr Id say no. I personally dont like the fully laoded BTLs off that much power... how much space does he have to work with? Also, please note that those are rather strong amps... but they have a little problem in that the subsonic filter is preset to 28Hz at a shallow 12dB/oct. If you are tuned above 30Hz, I would advise you to get an add on filter to augment this... most have been using the Harrison labs adjustable F-mod with good results. Its a solid margin of safety for $35... given that with 3500W things can go bad fast under tuning.Thanks,Scott
August 22, 200718 yr so my bro has a reg cab ford f150 and he wants a fully loaded btl 12 ran off a rockford 30001bd amp 1/0 wire 2 kinetics excessive amperage alt. what do you guys think.. he also said moneys not a problem.. so yeah..So yeah.
September 3, 200718 yr Author i meant what you guys think.. so what should we get then.. cuz he wants it loud as fu(K
September 7, 200718 yr What are the basic dimensions he has to work with for an enclosure? Im sure its rather shallow... Id rather see a couple of 12s with that amp versus a single 1. Pair of BLs would work if you have the space...
