Yep! Lot of birthsheets around saying the same.
They sell them on the store here too.
I run mine off of a 50x2 amp (piece of crap Sony) & I have the gain temp set at 1/4 & attenuated @ the deck by -8dB.
Not sure why you need two of them?
8 up front and 8 in the back(cargo)
im not gonna argue what im doing. i was simply asking about the amps.
lol, stand your ground
as far as the amps, I love those things, I've been eye balling them every time I go to my distributor. They have stacks of them. Once their gone though, their gone! Can't think of any use I would have for them. I saw a few birth sheets on the punch 150 around 800-900w RMS! For a $200 dollar amp, can't beat it.
as much as i dont want to admit it...yes they do rated power and yes they are cheap as hell.
mine does 300 @ 4 ohms
it was my dirty little secret in hopes that i would have enough cash to buy another one down the road, but alas the secret it out.
I wish I had some cash to try them out.
:woot: got 2 Punch45's and 2 Punch150s on the way!!!!
you think theses amps could be run @ 1.6 ohm per channel (rated to go to 2 ohm only...) for mids and highs?
also, how is the current draw on these?
Edited by pimpedout97x
Your 1.6 comment will really depend on the speakers. If the specs are off a bit I would say no, unless they are off in the other direction. If you actually measured the 1.6 I would say you are okay, but I know you didn't and I am not referring to DCR either.
Where did you order from?
the speakers are 8 ohm, and im referring to using 5 per channel. 5x 8ohm speakers in parallel = 1.6 right?
if not, ill use 4, and get a 2 ohm load.
