Posted August 24, 200718 yr 11cubes to work with...2btl 18's ported tuned to 35hz with 2k going to eachor 3 q18's sealed with 2k going to each?for the folks cant understand2 18's ported 4,000 watts or3 18' sealed with 6,000wattseither setup will be in a blazer walled off80i feel like such a noob
August 24, 200718 yr 11cubes to work with...2btl 18's ported tuned to 35hz with 2k going to eachor 3 q18's sealed with 2k going to each?for the folks cant understand2 18's ported 4,000 watts or3 18' sealed with 6,000wattseither setup will be in a blazer walled off80i feel like such a noobYOu are having the same brain fart that I am. Except I choosing between 2 15" BTL's or 4 15"Q's.....The Q's won though Out of your 2 choices, I would go with the 2 BTL's and put more then 2k to each if possible.
August 24, 200718 yr Author i know i need more power but right now i have 3 usamps 2000xi want 2 use them...if i traded or sold 1 i want a ab 500.180
August 24, 200718 yr Im figuring you want loud.... Id do the BTLs ported. Qs sealed would sound great, but still not have the same output as the BTLs around tuning...
August 24, 200718 yr Author Im figuring you want loud.... Id do the BTLs ported. Qs sealed would sound great, but still not have the same output as the BTLs around tuning...wow reallyeven with 2k going to each?i figured with the extra 18 and an extra 2k the 3 18's will be good...im actally trying beat out a truck that has 4 rf t1's in a ported box non walledi know based on cone area i would have hmm and i have slightly more power 6k vs 400080
August 25, 200718 yr i know i need more power but right now i have 3 usamps 2000xi want 2 use them...if i traded or sold 1 i want a ab 500.180Did you see the for sale thread on ca.com? That guy has 2 brand new for $8?? each.
