Posted August 24, 200718 yr right now i have 2 12 cvr's and a fusion powerplant 20006 amp i want to get a Fi.Q im thinking about getting a 18 =) my amp is rated at 1150wattsx1@1ohm says its a mono amp but it has 2 speaker outputs so if i want to run a Q at 1 ohm would i run it on 1 channel or on both i dont get it and should i get the Bp power with the amps rated 1150wattsand i was hoping i could get some tips on box building ive made a few for my cvr's but havnt noticed a big difference i was wondering how big the port should be and all that fun stuff that is the only part i have trouble with, when i build boxes i have a 93 jimmy s15 4 door i have plenty of room i thinkor should i just get 2 15 AA arsenals =? Edited August 24, 200718 yr by Skartisu
August 24, 200718 yr A standard Q18 will work on that power just fine if you set things up correctly. As for the AA Arsenal 15s... thats a tough call. Both would make for soild setups off of that power. Similar sized overall enclosures. While AA has the surface area advantage, Q has the overall linear swept displacement advantage.Let us know the basic outer dims you have and we can help with the box.Thanks,Scott
August 24, 200718 yr Author well my jimmy's measurements are 37.5 h 32 L 32 Dbut what would be louder im thinking the 2 12's will be but i also alrdy have 2 cvr's and i think i have another amp for them when i do get subs for my fusion amp, so 4 12's or 2 12's and a 18? hmmmm
August 26, 200718 yr I'd recommend sticking with subs of the same size if possible..Even though that amp has 2 sets of outputs it is still a monoblock amp...it really doesn't matter 'how' you hook the sub up to it, it only has one channelOverall the 18 should be louder for a musical application than the pair of 12's...now burping/spl that may be a different story...Thanks!-Nick
September 1, 200718 yr go with the q 18. i have 2 of them in my mercury moutaineer and you cant go wrong with them. i had one and it was insane for a single driver. i had a lil more power than you but it got crazy loud and sounded damn good doing it! pm me if you want to get indepth with enclosure designs for the q 18. ive tried so many and i have so many designs for that vehicle to meet your needs. let me know!
