Hello friends....
today i'll put carpet on my enclosure... but before ,i have just a last question for my box :bump:
In fact i can make it a little bigger .....
actually 3.6 cu ft 33hz and i can go to 3.9cu ft 32hz.. is it a big difference? the low will be best with 3.9 cu? more outputs,SPL ?
i'm waiting your answer...
thanks a lot and have a good day :domoslay:
Damien
Not that big of a difference, i doubt very seriously if you'd notice an audible difference between the two..
If anything the larger inclosure may be a smidge less accurate...but you'd probably only notice it if you had many many listening hours in with the subs...
Thanks!
-Nick
thanks NDMstang65....
i can put carpet now and install it in my truck....
