Posted August 27, 200718 yr What size and how many aeroports should I use?I'm thinking 3x6" ports for ~85sqin?Is this about right?
August 27, 200718 yr thats about maximum port area for a 5.3 cube box, 16sq inches per cubic foot.. going by the thread above it says 3-5cubes for a 15 not sure how all the extra space and port area will doprobably drop your power handling, anddd your output, not to mention SQ if you wanted any Edited August 27, 200718 yr by Scott
August 27, 200718 yr Aero's are different, for a 15 you honestly should not need more then 3 3" aero's, possibly 2 4" aero's or a single 6" aero would be adequate...Thanks-Nick
August 27, 200718 yr Author Aero's are different, for a 15 you honestly should not need more then 3 3" aero's, possibly 2 4" aero's or a single 6" aero would be adequate...Thanks-NickGiven a box with 4.5cubes GROSS...how long does a 6" aero need to be? How long would 2x6" aeros need to be? Looking for an output bomb around 45-50hz. Thanks Nick, good to see you around again. Edited August 27, 200718 yr by dopey
