Posted August 29, 200718 yr Will 15" BTL's work in a ported box for DD 9515 subs. Port area is 165" per sub and port is 9" deep. This is what I was told to use for the DD subs. This is a SPL set up only. I know this is more than FI recomends for port area. Total box area is about 17-18 cubic feet.
August 31, 200718 yr OK... how many subs and the total box for X number of subs is 17-18 cuft? Each sub has 165 sqin of port 9" long as well?Im sure itll work fine, but normally a little tweaking on things will optimize them for the application.
August 31, 200718 yr Author For a 1990 Chevy ext. cab pickup. I was told this be Michael Jones. Build box as large as can and 165" port area per sub 7"-9" long port for 2 15" DD 9515 subs . If could would rather use 15" Fi BTL's. Area behind seats comes close to 18 cubic feet internal box area. If have a different recomendation for box design I'm willing to listen. Looking at using 2 Memphis 4kw amps and 16 volt charging system. Edited September 5, 200718 yr by bdufner
September 5, 200718 yr Author Any suggestions on what to use. Need ideas. Want to start build for next year as soon as I can.
