Posted August 30, 200719 yr ok since i heard that ED is not a good company as far aas supporting problems with their subs i have decided to go with either the SSD or Arsenal 15 when i input them into WinIsd it says the SSD has more outout but the arsenal has a higher rear air port velocity and SPL just wanted to know which one would be louder i would be putting about 650 to the arsenal and about 900-1000 to the SSD with the flatwind coil option all help is appreciated oh and i want to use about 4 cubes net
August 30, 200719 yr i have heard the old arsenals and i would have to say the SSD would get louder while the arsenal being more on the SQ side of things.
August 30, 200719 yr Author kool i just wanted some input i been hearing nothing but great things about all the FI subs and i was leaning the SSD so i guess its final im gonna be ordering my SSD 15 probably tommarow
August 30, 200719 yr Admin The SSD can take more power, looks like we are going to have to change your user name to FifutureStar.
August 30, 200719 yr i have heard the old arsenals and i would have to say the SSD would get louder while the arsenal being more on the SQ side of things.With the copper coils, there's really nothing wrong with the accuracy of the SSD...I haven't heard a new Arsenal so I can't compare the two.WinIsd it says the SSD has more outout but the arsenal has a higher rear air port velocity and SPLDon't use WinISD, or believe anything it tells you.As for your what will be louder question, that's totally install dependent. You could make one louder than the other based on how well it's installed...
