Posted September 1, 200719 yr I've been a loyal kicker fan for years. I've been sold on an 18" Fi Q but I just need a little reassurance that it can have more output than a 15" L7 with 1000 watts rms. I know the Q will have better SQ but I mostly listen to country so not a lot of hard bass to keep up with. I have enough room to port either of the two.
September 2, 200719 yr Admin Out put is based on the install. You can get the Q very loud if you want, and you can choose options to fit your needs.
September 2, 200719 yr i cant imagine there would be a noticeble difference in output. you will notice a difference in sound though
September 3, 200719 yr I've been a loyal kicker fan for years. I've been sold on an 18" Fi Q but I just need a little reassurance that it can have more output than a 15" L7 with 1000 watts rms. I know the Q will have better SQ but I mostly listen to country so not a lot of hard bass to keep up with. I have enough room to port either of the two.What really is your issue? Do you want it louder or to sound better? To me its a no brainer, I couldn't handle having an L7 in my car period. Are you using the same amp? That L can take a lot more than you are throwing at it so the SPL portion shouldn't be that hard, the satisfaction of having a sub that can blend with your frontstage will only come with the Q and not the Kicker.
