Posted September 5, 200719 yr My friend is looking for some components and has about 175W @ 4 to play with and ofcourse wants to fill that void with speaks rated somewhere up there, but it seems to me there are more quality components in the sub 100W range.I noticed there are few passive component sets that are rated up over 100W RMS. Are there any high wattage components that are highly recomended? PS- Price range around 200-300
September 6, 200719 yr Admin If the end user does not want to go active and has a powerful 2 channel amp, it is a fine choice.
September 6, 200719 yr Author Can get the Kicker SS65.2 6-1/2" components in the 2-300 range anybody ever used these?Kicker SS65.2 6-1/2" 04SS65.2 Edited September 6, 200719 yr by MKader17
September 9, 200719 yr Author No one has any experience with these components? I figure being kicker top of the line they may be worth something
September 9, 200719 yr No one has any experience with these components? I figure being kicker top of the line they may be worth somethingI have not heard them, but they are supposedly very nice, for components.
September 10, 200719 yr Power handling will be pretty proportional to how low you expect any of them to play. I'd still pick the ones that sounded the best to me with some dynamic capability. Of course his needs and mine might be a bit different.
September 10, 200719 yr Power handling will be pretty proportional to how low you expect any of them to play. I'd still pick the ones that sounded the best to me with some dynamic capability. Of course his needs and mine might be a bit different.And to add, power handling/midbass response is also a function of the install. If you are locating them in the doors, sealing your doors to provide the driver a nearly IB enclosure will be a HUGE improvement over not doing so... as will fully deadening & using a sound barrier. This will allow you to get lower/more accurate while using less power.
September 10, 200719 yr Author Doors will be sealed and deadened, and, as usual, there is no chance of being able to demo these speaks before hand
September 12, 200718 yr the Kicker SS components are very nice if you can power them, 175x4 should be enough. super loud and crisp, only complaint i have is lack of midbass
September 13, 200718 yr the Kicker SS components are very nice if you can power them, 175x4 should be enough. super loud and crisp, only complaint i have is lack of midbassWhich right there makes them a very bad set of components in my book. Of course the other option is to blame the install which is the primary cause for poor midbass.
September 13, 200718 yr Author the Kicker SS components are very nice if you can power them, 175x4 should be enough. super loud and crisp, only complaint i have is lack of midbassWhere were the components and were they properly deadened?
September 16, 200718 yr I thought about using these but after talking to a Kicker employee I decided not to. He recommends the set but he said to go active. He didn't like the passive crossover network very much.
September 19, 200718 yr this post was started from my friend i have just joined! i now have decided to go active so now i have to make some selections! cuz i really wanna get my system up and running!
September 19, 200718 yr active > passive, chit tons of options for drivers as well. Any idea on what you are going to use for processing?oh, and btw
September 19, 200718 yr i plan on running the kicker 850.4, with 2 channels bridged to the 2 10"s, and then leave the other 2 channels for the mid bass. and then get an another amp for the tweets doin like 50 rms x 2.kicker amp specs http://www.sonicelectronix.com/item_3585_Kicker+KX850.4.htmlso i will have 175 x2x 4ohms to work with for the mids. any suggestions? Edited September 19, 200718 yr by Tmax98
September 19, 200718 yr Depends on the budget, mounting locations and crossover points...That's still a decent amount of power at 8 ohms, so you have a lot of choices.
September 19, 200718 yr i also plan on using the pioneer premier DEH-P690UB http://www.sonicelectronix.com/item_9008_P...DEH-P690UB.html
September 19, 200718 yr Depends on the budget, mounting locations and crossover points...That's still a decent amount of power at 8 ohms, so you have a lot of choices.do u think 50x2 isnt sufficent? i could splurge a lil and go like 75x2 or even 100x2 if its neccassary
September 19, 200718 yr If you use that deck and those amps, you still can't go active without adding a processor. I would suggest a different headunit for that reason alone.
September 19, 200718 yr Where are you getting those numbers from?Sonic is funny and states the numbers at 14.4. The amp is truly rated at 90wx4 at a normal voltage.
September 20, 200718 yr Author Where are you getting those numbers from?Sonic is funny and states the numbers at 14.4. The amp is truly rated at 90wx4 at a normal voltage. So your saying the 175x4@[email protected] only puts out 90x4@[email protected]? And even so doesn't your vehicle run at 14.4V?
September 20, 200718 yr Where are you getting those numbers from?Sonic is funny and states the numbers at 14.4. The amp is truly rated at 90wx4 at a normal voltage. So your saying the 175x4@[email protected] only puts out 90x4@[email protected]? And even so doesn't your vehicle run at 14.4V?What Sean (M5) is saying is the big numbers they post are peak outputs full tilt. Always look for the 12 volt rating....better to be a little under rated than waaay over rated. I know where there is a mint Eclipse 8454 for sale for $250, has built in two way x-over plus a sub out and time alignment. Perfect for cutting your teeth in the active realm. If you have your heart set on the Pioneer, you will need a outboard crossover to do the dirty work. The are a ton of drivers out there that can be matched with the power you have on tap and give you a great sounding system. Sundown amps (on here) makes some great amps, for some great prices, Zed is another, and these truly come in under rated, not by a lot, but because they test them in real world conditions. If you have a hefty alt and the current available for them, they will outdo what they are rated for. You want some head room so when that big cymbal crash or kick-drum beat hits, it maintains it authority and clarity. Driving your amps into clipping even for a peak can be catostrphic (experience speaking there my friend). Let us know what your budget is, what you are trying to achieve (big SPL, total SQ, etc) and there are a lot of people on here that will steer you in the right direction. Edited September 20, 200718 yr by finebar4
