Posted September 14, 200718 yr I have 2 US Amps Md3's strapped. My question is will both of the amps be putting out AC Voltage or just the master? I went out there today and on music my master was putting out AC volts but my slave was not putting out any AC volts. Both of my subs work and they are wired seperate so both amps are working but the slave is not reading any AC voltage.
September 14, 200718 yr Both of my subs work and they are wired seperate so both amps are working but the slave is not reading any AC voltage.The wording above sounds like you do not actually have them wired "strapped".If you truely have them wired strapped, then you have the (+) of the master amp wired ot the (+) of the load, the (+) of the slave amp wired to the (-) of the load, and the (-) of the master amp wired to the (-) of the slave amp. You should have A/C voltage between the (+) of the master amp and the (+) of the slave amp.Are these 06 or 07 style amps? Are you refering to the MLT function?
September 14, 200718 yr Author I have the new models with the MLT and I have them linked the way it says to in the manual.
