DB Drive PL15D2 15''? it an older sub i cant find very much info on it but this is what i found (sorry since its not much)
http://www.shopping.com/xPF-DB-Drive-PL15D...S-SUBWOOFERS-15
EDIT: heres a little more info i found
Features 3" dia high temperature 4-layer voice coil
Extreme excursion motor structure & suspension
Multi-layer treated paper cone
Layered UV treated foam surround
Dual spider linear design
Strontium (SR) magnet with attractive rubber boot design
Attractive matte black anti-resonance die-cast aluminum basket
Integrated tinsel leads for high excursion
Machined push-button terminals
Rigid dustcap design 15" 2000 watts Dual 2 ohms voice coils Sensitivity: 92 dB 220 oz magnet
Edited by ballin millenia
No clue if it is a standard American 3" coil or not...it could be one of the weird Chinese ones...
Thanks
-Nick
well what do i need to do to find out?
Measure the ID and OD of the coil that is in it with a set of calipers...
Should be 3.000" ID
Thanks
-Nick
ok ill get it measured asap
