Posted September 22, 200717 yr Hey guys, as the topic says I have a problem with a SSD 12... the spider feels very weak in a spot like there is a crack under the top one.So my question is will it be fine to run like that? (i don't know how long its been that way but it worked fine till the day I took it out) or do I need a recone so it doesn't get any worse?Thanks
September 22, 200717 yr They are going to get soft after running them for a while...If it becomes an issue then it should be covered under warrantyPost a picture if you get a chance.Thanks-Nick
September 22, 200717 yr Author ok well I actually looked at it with some light and there is a rip in it....Thanks
October 1, 200717 yr Does the speaker bottom out or the like? Usually they say beat on it [ music ] till it becomes a problem if it becomes a problem,.....they will help you if it does
