Posted June 21, 200422 yr Ok so i got my tape measure went to the trunk and figured out my not quit max volume i could use for a box and came up wt 15.5cu^3 big ass trunk huh, and i was thinking about porting it to 46hz, but i would just stuff it for daily..i was planning on 2 SX 15's....but ya neva know about subs these days..i should put up hella numbers wt this setup :boink:
June 21, 200422 yr Author Any body think this is too bigoh and the box was gone look like this _______________ |.........................| |.....................| | |_sub1__sub2_|....|ignore the dots
June 21, 200422 yr Make sure you can get that into your trunk. Seems slightly big for a trunk box. You could use 2 sx 18s if you could get that much space in there...
June 22, 200422 yr Seems huge.I'd be tempted to go with the aforementioned idea of using 18's if your budget allows for it.- Steve
June 22, 200422 yr Author depends on the job to be either 9.50$ an hour at Hewlett Packer or 20$ an hour working construction...
June 22, 200422 yr Author Man i think i'm gettin a navigator in a few months and that box def aint gone fit, haha2 18's, would idk, i could just atke out the back seat and then i could have 30cuhahahaOh well 1 thing at a time
