Posted September 25, 200718 yr what would happen to the sound if i put either a 12" assasin or arsenal, hell, even a atlas or avalanche in a 1.5 cu ft ported box instead of their recommended sizes?
April 17, 200817 yr I was wondering the same thing. I'm either going with 1-12'' sealed or 1-10'' ported and I'm limited on space. Then I noticed the Havoc 12'' can be in 1.5ft^3 ported and it caught my eye.
April 17, 200817 yr Smaller ported boxes are generally less efficient at lower frequencies. But they are more efficient at a specific frequency. You could loose some low end extension, and it could feel less "boomy" but should be a tad bit more punchy. Just make sure you have enough port area.
April 17, 200817 yr Smaller ported boxes are generally less efficient at lower frequencies. But they are more efficient at a specific frequency. You could loose some low end extension, and it could feel less "boomy" but should be a tad bit more punchy. Just make sure you have enough port area.my thoughts exactlly !!!i use a small 3cf box @ 54Hz to do SPL due to the control i have over the cone. tight and accuret.where as a 7cf box for 1 sub @ 36Hz is Hella Bass Edited April 17, 200817 yr by Lord Baccus
