Posted September 28, 200717 yr Sooooo, I was asked by a friend who is about to order some BLs to ask on here. He is gettin the fully loaded BLs and wants to know if they can take 2k watts daily???? The longest he blares his system for at a given time is about 30min, but his current setup is crap so i doubt it will be full crank with BLs.
October 3, 200717 yr The fully loaded versions are rated at up to 2000W in the proper setup. We bring them right up to where the standard BTL comes in. While we dont always recommend 2000W to each as it depends on sub size, enclosure, tuning... and other factors. Those that do have that much going to them have been fine. Setting the subsonic filter is key on higher powered setups. Easy to kill a sub with that much power if things arent set up correctly (freeair below tuning with 2000W is bad )Thanks,Scott
