Posted September 28, 200718 yr I searched the specs thats pinned but theres nothing about the older amps...a friend has the VFL 400 and i was woundering what it would do ???might not be vfl ?but the amp is a Us amps & its about 7ft long Edited October 11, 200718 yr by denim
September 28, 200718 yr Author sorry the amp i am wanting info on is a Us Amps its as tall as i am !!! 6ft or better the thing is a monstor but i cant make out what it says on the board other than ......400, has lots of red and black 8ga wire comming out of 1 endlooks like this 1 but its twice the amp.... Edited September 28, 200718 yr by Lord Baccus
September 29, 200718 yr the vlx 400 is about 4 ft long and 2400 watts @1 ohm. i never seen a 6 foot us amp. ill will like to know what it is also. have any pics of the amp?
September 30, 200718 yr Specs per my 92 U.S. AMPS broshure are as follows:200 per channel @ 4ohms400 per channel @ 2ohms800 per channel @ 1ohm1600 per channel @ .5 ohm3200 bridged @ 1 ohm44 inches longNeeds 400 Amps of inline fusingQuad power suppliesVari-Loud equalizationAnd as we all know under rated. Last time I was involved with these was in the mid 90s
October 1, 200718 yr You're probably thinking of that rather 'rare' US Amps amp.. I can't remember THE exact model..But I saw an install in an Eclipse that used it & a DD 9515.. it took up the entire back seat of the Eclipse.. length wise.stratusRT01 did the install.
October 2, 200718 yr Author does anyone have pics of the Vlx 400 ???id know it if i saw it !!!it is unmistakableoh snappppp i found it on ebay http://cgi.ebay.com/RARE-US-AMPS-U-S-AMPS-...2QQcmdZViewItem Edited October 2, 200718 yr by Lord Baccus
October 2, 200718 yr Author http://www.ampguts.realmofexcursion.com/USAmps_VLX-400/That is a winner the 1 i saw looked like the 1 on ebay / ony had a small gain knob.....and bigg@ss wires comming out the other end
October 10, 200718 yr IIRC, the old VLX-400s were rated at 2400 watts. Either way, these things were badass...if you could fit one in your car.
