Posted October 6, 200718 yr I have a kicker l7 2ohm, its wired for a 4ohm load, so should i pick an amp with 750w RMS at 4ohms? does anyone have some suggestions?Thanks
October 6, 200718 yr To save money perhaps you should wire it to a one ohm load, and with that driver you can surely throw more power at it than 750.
October 6, 200718 yr Author To save money perhaps you should wire it to a one ohm load, and with that driver you can surely throw more power at it than 750.You have an awesome car! Im currently saving for a 95 M3.If I wired it for a 1 ohm load what amp would you recommend?would these be good?http://www.onlinecarstereo.com/CarAudio/Pr...ProductID=16696http://www.onlinecarstereo.com/CarAudio/Pr...ProductID=16338http://www.onlinecarstereo.com/CarAudio/Pr...ProductID=16367http://www.onlinecarstereo.com/CarAudio/Pr...ProductID=17675
October 7, 200718 yr To save money perhaps you should wire it to a one ohm load, and with that driver you can surely throw more power at it than 750.You have an awesome car! Im currently saving for a 95 M3.If I wired it for a 1 ohm load what amp would you recommend?would these be good?http://www.onlinecarstereo.com/CarAudio/Pr...ProductID=16696http://www.onlinecarstereo.com/CarAudio/Pr...ProductID=16338http://www.onlinecarstereo.com/CarAudio/Pr...ProductID=16367http://www.onlinecarstereo.com/CarAudio/Pr...ProductID=17675Thanks, had an E36 myself as well. I can't say that I am a fan of any of your amp choices. If you are truly that budget limited, please buy something used and not any of those.
October 8, 200718 yr Or the saz 1500D. I had my brothers L7 dual 2 running off my 1500D & it liked the power just fine. Check the Sundown B-Stock section, it'd be worth spending another $50 on that amp.If not you could go with a profile AP2000, not a crazy amp but also pushed my brother L7 well for the bit of time he had itgood luck w/ your search.
October 8, 200718 yr Author http://www.onlinecarstereo.com/CarAudio/Pr...ProductID=18179 would this be a good choice
October 10, 200718 yr Here is the best advice i can give you on amp choiceRead up on comments about the amps you are linking to.. read about the amp itself, the products performance and price per watt (REAL WATT)then go to the Sundown section on this forums and Read up on the Sundown ampsThen make a choice Or you can just sve yourself time and email Denim or SSAUdio for a quote on a Sundown Edited October 10, 200718 yr by theabunai
October 10, 200718 yr http://www.onlinecarstereo.com/CarAudio/Pr...ProductID=18179 would this be a good choiceIt isn't worth being used as a paperweight.I am also concerned with the above post. Recommending a really good amp like the Sundown followed by a crap Profile recommendation.The Sundown is a great choice!!
