Posted October 7, 200719 yr Okay guys, i have a Fi 15" BTL with cooling, 3rd magnet, and hixmax coil with the dual 2 ohm. its the in a 6.5 foot ported enclosure, only 5 feet though after port and sub displacement. Its tuned to 39 Hz and is 1" all the way around with a 1.75" front face. Its also got internal bracing so im not worried about the sub blowing apart the box in any means. I am looking to spend around $500 at the most on an monoblock. I was looking at the hifonics BXi2607d which is 2600 RMS at 1 ohm, but i keep hearing bad things about hifonics and not so sure if i want to go that route anymore. Im looking for an amp to put out some serious power because i want this BTL to be herd from blocks away. is any one familiar with the EARTHQUAKE PHD5000W which puts out 3000 RMS at 2 ohms. Please give me suggestions, and please remember im looking for loudness before quality. thanks -wes
October 8, 200719 yr Okay guys, i have a Fi 15" BTL with cooling, 3rd magnet, and hixmax coil with the dual 2 ohm. its the in a 6.5 foot ported enclosure, only 5 feet though after port and sub displacement. Its tuned to 39 Hz and is 1" all the way around with a 1.75" front face. Its also got internal bracing so im not worried about the sub blowing apart the box in any means. I am looking to spend around $500 at the most on an monoblock. I was looking at the hifonics BXi2607d which is 2600 RMS at 1 ohm, but i keep hearing bad things about hifonics and not so sure if i want to go that route anymore. Im looking for an amp to put out some serious power because i want this BTL to be herd from blocks away. is any one familiar with the EARTHQUAKE PHD5000W which puts out 3000 RMS at 2 ohms. Please give me suggestions, and please remember im looking for loudness before quality. thanks -wesGet a Sundown Audio SAZ-1500D
October 8, 200719 yr I'd actually suggest either 2x SAZ-1500D Sundowns strapped OR a SAZ-3000Dbut he said 500 bucks for a amp. I dont know if he can get his hands on a 3000d for that price unless its used
October 8, 200719 yr Author ok, ive taken your advice and hear is my solution:http://www.soundsolutionsaudio.com/forum/i...showtopic=11792
