Posted October 8, 200718 yr Im just tryin to see how loud decibels are from 120, 130,140, and 150.I think a while ago someone told me that 130db's was like gettin hit in the chest and its very hard to breathe at 150. Is this true? Can someone give me examples of each range of decibels.
October 8, 200718 yr * Near total silence - 0 dB * A whisper - 15 dB * Normal conversation - 60 dB * A lawnmower - 90 dB * A car horn - 110 dB * A rock concert or a jet engine - 120 dB * A gunshot - 140 dB
October 8, 200718 yr Hearing loss can happen with exposure to just 80db. Do realize that dB's are logarithmic.
October 8, 200718 yr I had this handy. Decibel (Loudness) Comparison ChartEnvironmental Noiseweakest sound heard 0 dBnormal conversation at 3-5 ft 60-70 dBdial tone of telephone 80 dBcity traffic inside car 85 dB1983 OSHA monitoring requirements begin 90 dBtrain whistle at 500 ft. 90 dBsubway train at 200 ft. 95 dBregular sustained exposure may cause permanent damage 90-95 dBpower mower 107 dBpower saw 110 dBPain begins 125 dBpneumatic riveter at 4 ft. 125 dBjet engine at 100 ft. 140 dBloudest sound that can occur 194 dBMusical Noisenormal piano practice 60-70 dBfortissimo singer 3 ft. away 70 dBchamber music in small auditorium 75-85 dBregular sustained exposure may cause permanent damage 90-95 dBpiano fortissimo 92-95 dBviolin 84-103 dBcello 82-92 dBoboe 90-94 dBflute 85-111 dBpiccolo 95-112 dBclarinet 92-103 dBfrench horn 90-106 dBtrombone 85-114 dBtimpani & bass drum rolls 106 dBaverage Walkman on 5/10 setting 94 dBsymphonic music peak 120-137 dBamplified rock music at 4-6 ft. 120 dBrock music peak 150 dBNOTES:The brass section playing fortissimo can drown out practically the whole orchestra.One-third of the total power of a 75-piece orchestra comes from the bass drum.High frequency sounds of 2-4,000 Hz are the most damaging. The uppermost octave of the piccolo is 2,048-4,096 Hz.Aging causes gradual hearing loss, mostly in the high frequencies.Speech reception is not seriously impaired until there is about 30 dB loss; by that time severe damage may have occured.Hypertension and various psychological difficulties can be related to noise exposure.The incidence of hearing loss in classical musicians has been estimated at 4-43%, in rock musicians 13-30%.
October 11, 200718 yr Author thanks for the replies...but that was a lil deeper than i was expectin. Really i think a better question would have been how does it feel?like at what dbs does it take to make it hard to hear the person sittin next to you n the car? Hard to breathe?
October 11, 200718 yr Remember, those are in dBA, not a single frequency reading like you're going to get from a sensor like a Termlab.150dBA is a lot different than 150dB @ 50Hz.
October 12, 200718 yr There's really no clear answer to your question...it'll depend on the frequency, vehicle used, setup of the vehicle, etc...
October 12, 200718 yr Remember, those are in dBA, not a single frequency reading like you're going to get from a sensor like a Termlab.150dBA is a lot different than 150dB @ 50Hz.care to explain the difference? wheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee
October 12, 200718 yr a really cool thing to do is to play a slow sine sweep while talking to someone in the vehicle. Dave and i did this and at a moderate level the sound would completely drown out what he was saying. same with my voice. I'd say his two 10s were around 130-135db but that's completely guessing. with lower frequencies it's all about frequency. When i'm screwing around with 18hz (not even in an spl system, just my 15" Q sealed with about 1300W) i can feel a pressure that is not nice in my head. with a sine wave around 45hz it's not really all that bad until you get to a much higher level. the stratus's 143@48hz was loud but didn't really bother you at all.
October 12, 200718 yr Weighted readings are over the whole audio bandwidth, varying in how different octaves may be attenuated...an A-weighted measurement is going to have a lot more higher frequency (and therefore damaging) info than a single 50Hz tone.
October 12, 200718 yr Weighted readings are over the whole audio bandwidth, varying in how different octaves may be attenuated...an A-weighted measurement is going to have a lot more higher frequency (and therefore damaging) info than a single 50Hz tone.ok. so what's the difference in A and C weighting? and exactly what does it mean to have an A weighted measurement? is it in the fact the A rating is for higher freq compared to a C rated one being for lower octaves? or am i way wrong?wheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee
October 14, 200718 yr Weighted readings are over the whole audio bandwidth, varying in how different octaves may be attenuated...an A-weighted measurement is going to have a lot more higher frequency (and therefore damaging) info than a single 50Hz tone.ok. so what's the difference in A and C weighting? and exactly what does it mean to have an A weighted measurement? is it in the fact the A rating is for higher freq compared to a C rated one being for lower octaves? or am i way wrong?wheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee Google would help you with that. I can't remember what it is off the top of my head.
October 15, 200718 yr Both are just different acoustic weighting curves. They are both made to be simple to calculate and not really for the most accuracy, but the basic idea is that your ear is not a linear device and is more sensitive to some frequencies than others. A weighting is a method of re-flattening your ears response curve to model how you would perceive the sound. C weighting is similar but also compensated for higher volumes. Both are very simple linear additions/subtractions of dB at each 1/3 octave bin frequency.
October 20, 200718 yr Heres my views on it. Lets just say a note in between 35-45hz is used for all.120dB - You can feel a little bass, mostly just blends into the music and sounds very smooth.130dB - A pretty average system. A couple low end 10s or 12s with a couple hundred watts.140dB - Some people can start to feel the pressure in their ears, and most people not into systems say its pretty loud.145dB - Starts to get pretty loud. You can feel the bass throughout your body. Pressure starts to build. Pretty loud street system.150dB - If you got virgin ears, you will probably chit your pants when the line drops.155dB - Breathing becomes difficult inside the vehicle, your ears really hurt, and even outside the car you can feel pressure on your chest.158dB - Insanely loud. Your ears hurt like you wouldnt imagine, your vision is blurred to the point where its hard to see, and you really have to concentrate on breathing.160dB - Rediculous. Breathing is pretty much impossible, and just the flat out pressue feels like your body is being crushed.Could go higher, but ~160dB is loudest Ive ever heard on music.
October 20, 200718 yr ^^ All depends on your set up on the pressure wise. My boys 12" BTL wasn't super loud but you could the pressure out side of his car pretty good. (no 29hz tuning)
October 29, 200718 yr Author Heres my views on it. Lets just say a note in between 35-45hz is used for all.120dB - You can feel a little bass, mostly just blends into the music and sounds very smooth.130dB - A pretty average system. A couple low end 10s or 12s with a couple hundred watts.140dB - Some people can start to feel the pressure in their ears, and most people not into systems say its pretty loud.145dB - Starts to get pretty loud. You can feel the bass throughout your body. Pressure starts to build. Pretty loud street system.150dB - If you got virgin ears, you will probably chit your pants when the line drops.155dB - Breathing becomes difficult inside the vehicle, your ears really hurt, and even outside the car you can feel pressure on your chest.158dB - Insanely loud. Your ears hurt like you wouldnt imagine, your vision is blurred to the point where its hard to see, and you really have to concentrate on breathing.160dB - Rediculous. Breathing is pretty much impossible, and just the flat out pressue feels like your body is being crushed.Could go higher, but ~160dB is loudest Ive ever heard on music.thats what i was lookin 4, thanks
October 29, 200718 yr 130dB - A pretty average system. A couple low end 10s or 12s with a couple hundred watts.I know of a few very non-average setups that won't come close to this number
October 29, 200718 yr If it were front stage, 130dB would be average.If by average you mean excruciatingly loud and nearly unbearable.
