Posted October 13, 200719 yr i think i'm stealing andy's idea where he used a sonotube, passive radiator setup. i have a maw12 and a kicker kx400.1, will be using a tube.....now, i need the pr. other then the ones from boston and tc, anyone know where i can get a mach 5 one? lol. actually, looking for a budget one. maybe a mach5 cone/basket?(i know that's not the best way to do this, but it is a budget system in a budget car)thoughts? ideas? links?thanks ahead of time!wheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee
October 13, 200719 yr I believe Creative Sound Solutions in BC is selling PR's now. Might want to check them out...
October 13, 200719 yr Parts Express sells Dayton ones up to 15", and Madisound & Solen sells Seas ones (though I think Seas stops at 8" or 10", IIRC).
November 7, 200719 yr Author i'm thinking that's too much money for the hooptie...so about a 6th order bandpass? lol...i just want loud for this car. could care less about overall sq, for now.mark, any suggestions on a 6th order? i'll be using a kicker kx 400.1, ~ 475wrmswheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee
November 29, 200718 yr Author what? no 6th order suggestions,lol???in any case, just got the new PE catalog, and they have some cheap PRs in there, and they look similiar to the mach5. so i think i'm going that route again. will be installing the system this weekend in a temporary sealed box, but am thinking the sonotube/pr will be the final design.what are the advantages to the sonotube? and any links to pr tuning? will probably be using the 12 pr, though the thought of using the 15 and messing with people's minds has some appeal.wheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee
November 29, 200718 yr Well, building Sonosub is certainly much quicker. You can have a ready-go "box" in a couple of hours. No need for bracing since vibes are dispersed evenly around the tube. Just slap on end caps, drill some holes and you're done.Looks, placement and size are a few of the downfalls to Sono's.I have not played much with PR's in the past, and info on exactly how to tune them is somewhat limited. You can probably start with punching the numbers into WinISD Pro to see what you get.Perhaps someone else can chime in here...Here's a link to some info:http://www.diysubwoofers.org/prd/
November 30, 200718 yr Author I'd rather port than PR in a car.this is more of a trial and error project, and since it's in the hooptie, something that can be thrown away if needed. the hooptie already has a couple of prs in it ( the front 3.5s are in enclosures with 5.25 prs) so i thought why not. teh prs are like 15-16 bucks in teh new pe catalag (or something like that) and it would be cool to play around with one.thanks mark for the info....it'll be a weekend project that'll begin soon. right now the maw12 will probably jsut be sealed as i have that box lying around. wheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee
December 2, 200718 yr Author oh, i will. it'll be a 12" pr (price is only $27) and a sonotube, maybe "V" shaped. i've got lots of thoughts going through my head.wheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee
December 2, 200718 yr Author For a PR, you'll need at least 2x the swept volume of the active driver.??really, i need help on this...i'm using a maw12 for the sub woofer, will grab two prs if need be...wheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee
December 2, 200718 yr Scott is right - go with either a 15" or two 12's. Since you're using a Sono, a single 15" should fit the bill nicely.Of course, that would make your Sono much larger than you anticipated...m
December 2, 200718 yr Author ok...i've got the sono in my head, lol....and it'll be two prs, 12", and the maw12. link to how i tune them?wheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee
December 2, 200718 yr Author http://www.diysubwoofers.org/prd/i thank you sir!after reading that page, i guess i picked a good sub, lol. with a qts of .27 it fits right in the recommended range for a pr.so, to get this to layman's terms...i design a ported enclosure for the maw12..i then do the equations to determine what the two prs "effective"port radius would bei then get the length of port, and figure out it's volumedo the math and convert volume to weight and that's what i need the prs to weigh.and simple test is to send sine waves at the pr in the otherwise empty encloure to dtermine if it's tuned correctlythat sound about right?wheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee
December 2, 200718 yr Author R = (Sd/PI)^0.5i need a little help with this one...if sd of each radiator is 480cm^2, what is the effective radius of a pair of them? i get 153, but i'm sure that's wrong.wheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee
December 2, 200718 yr Author ok, double check my math... if i'm using a pair of 12" pr with an sd of 480cm^2, my effective radius (combined) is 10". this relates to a 20" diameter port, (or two 10" ones, length is 175.75 per that way) in a 2ft^3 box means a 351.5" long port for a tuning of 34hz. converted to volume and then to weight, that means roughly 433g divided between the prs. each pr has a mms of 200g, so i would need to add 16.5g to each pr for a rough start?btw, the pr part number i'm looking at is SD315 at partsexpress.....and does 2ft^3@34 with ~475wrms sound ok to you mark?wheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee
