Posted October 18, 200718 yr I bought an rlp 15 today. Mike is the man btw.I dont know what kind of amp I need.I have a clk and will be doing a 2.0 cft boxI want club-type bass if that makes sense.I like rap and house music. I need an amp, and I think I want to do my front speakers as well because i have blose right now I have an avic d2 as my deck.what kind of tweets/midrange do I need?as affordable as possible, but I want them to be able to keep up with the bass.Pleaseeeee help me with your suggestions.thaaaank you
October 18, 200718 yr Author for the amp, <300for the components, I want to keep it relatively affordable like only a few hundred How much power would I be sending to it with the SAE-1000D at d2 or should it be installed differently?thanks Edited October 18, 200718 yr by rish
October 18, 200718 yr Components I would look at DLS, or Rainbow SLC Kicks, many sets under 300. You could also look at Memphis Amps. MCD 1000 is what I had on my RLP 15. It should be perfect sealed. The sundowns are good as well.
October 25, 200718 yr Author OK i am a little lost.I have the rlp 15 d2What type of power at what impedance would be the best?I was thinking about the Pheonix Gold RSd1200.1and doing 750w @4 ohm?Im still kind of lost on this. I don't know what I need to get.i want to keep it at 300 or belowany help appreciated
October 25, 200718 yr What was wrong with the SAE-1000D that Scott recommended? It does 1kw at 1 ohm. And thats about what you need.
October 26, 200718 yr Author The only problem is that it is too expensive Is there anywhere online to get it cheap?
