Posted October 23, 200719 yr Hey guys im looking to try out the maxx link but i have a question for ya. Im gonna be running 4 kicker zx2500.1 amps and 2 18in Btl dual 1 ohm subs. The zx amps are 2 ohm stable and i was wondering if there is any possible configuration to have the amps see a 2ohm load once strapped. Also would i be better without the maxx link and running each amp to each coil? What ohm loads could i see there. thanks
October 23, 200719 yr The maxxlink is just a glorified signal splitter/line driver. Nothing more.With four amps there is no possible way to get 2 ohms to each amp. If you had gotten DVC 2 ohm subs, then you'd be in business.
