Posted October 30, 200719 yr so im trying to decide between these four diffrent types i will be getting 2 15" i just dont know which ones what ones would u pick for SPL and some SQ and give reasonshttp://cgi.ebay.com/Cadence-Daytona-15-RVC...1QQcmdZViewItemhttps://ssl.perfora.net/www.ficaraudio.com/...view.shopscripthttp://www.soundsolutionsaudio.com/shop/in...p;productId=194http://www.soundsplinter.com/rlp15_subwoof...nformation.htmlalso considering these since they are on salehttp://www.woofersetc.com/index.cfm?fuseac...Product_ID=5534also can people post some links to some good amps that can power atleast 2000 watts rms Edited October 30, 200719 yr by SEC
October 30, 200719 yr Your Fi Audio link isn't working, but I'm planning on getting a Fi BTL15. From what I've read, they're real tough subs, backed by awesome support. Get the upgrades, and you're good for more then the rated 2000W. As for amps, Sundown Audio makes a 3000W @ 1ohm model that can be bridged for 6000W @ 2ohms.http://www.sundownaudio.com/pp3000d.htmlI'm sure theres other big number amps, but I'm sold on Sundown too, from what I've read. You got an upgraded electrical system in your car, or planning to upgrade? A 2000W amp is going to require a healthy amount of juice to power.-Trevor
October 30, 200719 yr As for amps, Sundown Audio makes a 3000W @ 1ohm model that can be bridged for 6000W @ 2ohms.http://www.sundownaudio.com/pp3000d.htmlThe amp can be strapped with another 3000D for a final wattage somewhere in the neighborhood of 6kW.There is no "bridging" of Mono (1 channel) amplifiers.
October 30, 200719 yr Admin Bridging is using a 2 channel amp and wiring it down to function like 1 channel by bridging the two together. Strapping is basically like bridging two separate amplifiers together to act as one.
October 30, 200719 yr Author Your Fi Audio link isn't working, but I'm planning on getting a Fi BTL15. From what I've read, they're real tough subs, backed by awesome support. Get the upgrades, and you're good for more then the rated 2000W. As for amps, Sundown Audio makes a 3000W @ 1ohm model that can be bridged for 6000W @ 2ohms.http://www.sundownaudio.com/pp3000d.htmlI'm sure theres other big number amps, but I'm sold on Sundown too, from what I've read. You got an upgraded electrical system in your car, or planning to upgrade? A 2000W amp is going to require a healthy amount of juice to power.-Trevorya i fixed the link im just getting 2 Fi bl's 15"
November 5, 200719 yr Author im kinda considering some type x though has anyone heard both in action how do they compare? for instance i know the type x have better SQ but do they hit as hard? what im trying to figure out is it gonna be a little SPL loss from the Fi to the type x cause im willing to lose a little SPL for alot of SQ but want i dont want to do is lose ALOT of SPL for a little more SQ Edited November 5, 200719 yr by SEC
November 5, 200719 yr I have experience with the Fi BL's and have only heard Type-X'sbut what i'll say is that they're defintely geared towards SQ. In the Alpine line-up, the Type-R's are even more SPL oriented then the X's.I'm going to go out on a limb and say maybe what you're gearing towards is the Q's over the BL's if you want some SQ based with good ouput.As for how the Q's line up against the X's...i'm not real sure. But i'd have to lean my way towards the Q's in overall performance. (again, this is with limited first hand experience)
November 5, 200719 yr Author ya but i am kinda aiming for SPL i was just seeing if i could get if i could get the same amount of output with the type x's as the Fi Bl's but with a little more SQ out of the type x
November 5, 200719 yr I own 2 10" X's and they will get loud, I had mine runnin in a 91' Mustang HB off my SAZ3000D in a 3.0ft3 vented enclosure tuned to 32Hz and they sound good and hit tight. You do realize that Alpine doesn't make a 15" type X.You might want to check out TC's Audiopulse drivers. I ordered 2 15" Revos still waiting for them though!!
November 5, 200719 yr Type X's CAN get loud but as stated before they are more SQ oriented.....as for the AudioPulse...probably great stuff, but what SEC is looking for...going to be way out of his pricerange...
