Posted November 3, 200719 yr Hi Im Getting To Alpine Type R'S 10 In A Ported Box What Amp Should I Get I Was Thinking A Kenwood 1800watts Amp
November 4, 200719 yr Is that two? Are you completely sold on the Type R's? There are a ton of better options available.Really need a budget for an amp recommendation.
November 5, 200719 yr Author HI AgainWell I Was Thinking If I Should Get The Two 10 Type R'S Or Just One 15 Type RAnd My Budget Is $230 And Down For The Amp And $230 For The SubsBut This Is Going To Be My First System So Im Putting It In A 03 325i BmwAnd All So Can You Tell Me With Amp Gauges I Need The Budget Price For That Is $70 And Under Also Ordering It Online.........Thank You:thanx:
November 9, 200718 yr Are you deadset on the Type R's, and if so why? Kenwood makes nice amps, they're pretty cheap and reliable, and most that I've seen do close to rated power.
November 9, 200718 yr Personally I wouldn't buy the Type R's nor a Kenwood amp but it would help to understand your goals.
