Posted November 5, 200718 yr Ok. i am planning on getting 2 15'' Bl's. (Dual 1 ohm, cooling, and flatwind). How much power can i feed them without buring them up?
November 5, 200718 yr Most people are running 1500W or so to each for a solid daily setup. There are people that run more and less... just depends on your setup and listening habits. With the cooling and flatwind it takes you just about up to where the standard BTL does (at about 2000W RMS). But you will need to make sure that the gains and subsonics are set correct to avoid issues.Thanks,Scott
