i'm not sure what would be the best way to wire my new bl...if you guys could help that'd be great..it's going to be put to a jl 1000/1 thanks in advance..and if you have a diagram post that to..thanks
Wire the voice coils in series, so the amp sees a 2 ohm load.
The cool thing about the 1000/1 and amps like it is that if you add another dual 1 ohm driver, you'll still have the same amount of power at a different impedance.
agreed here's a diagram for you
http://www.rockfordfosgate.com/rftech/woof...mp;woofer_imp=3
only difference is, your's is dual 1 ohm not dual 2 ohm, so you'd get a 2 ohm load not a 4 ohm like the diagram shows
