Posted November 16, 200717 yr Ok, i just bought an us amp md3d, and i was wandering whether to get 2 bl 15's or 1 btl 15 fully loadedThe bls would be more but which one do you think i should get, want the loudest one possible, bass wise, one that hits harder.
November 16, 200717 yr I thought space was a problem??? (2) BL 15's require double the box size of the single BTL 15. . . .Brian
November 16, 200717 yr Author I thought space was a problem??? (2) BL 15's require double the box size of the single BTL 15. . . .Brianyes i know. If i got the 2 bl's i would have to cut the grooves off the bottom of the trunk where it sticks out, and i would have about 7 ft of air space.
November 16, 200717 yr If you want to cut the car - 2 BL 15'sIf not, one 15" BTL. I run my BTL's in 3.15 ft^3 each. You could get away with less airspace for the pair of BL's if would keep from having to cut the car up. . .Brian
November 25, 200717 yr i have 2 fully loaded BL's in a 6.5 ft vented tuned at 33 hrz.. I THINK that the air space rating is 2 ft -8 ft persub. so MY thoughts are 6 ft is ok, but ask SCOTT from FI hes the man
