December 5, 200718 yr Author actually 0.2% is really high..... i was thinking in the 0.05 range.... did you mean 0.02?
December 5, 200718 yr Admin The Kicker SX series have a lot of adjustability with the digital eq's built into them. 0.2 THD FTWI still want a 4 channel.
December 5, 200718 yr wow What happened to the good old amps of the late 80's early 90's with thd's like .004, like the old linear powers, ppi, audio art.. Now a good amp has a THD of .2 or something
December 5, 200718 yr actually 0.2% is really high..... i was thinking in the 0.05 range.... did you mean 0.02?With a wall and presumably not-the-best source material, do you actually think you're going to be able to hear the slightest difference?I had a 2A3 triode amp that was around 3% THD just under the clipping threshold...but the harmonic content was quite different too
December 5, 200718 yr I had a 2A3 triode amp that was around 3% THD just under the clipping threshold...but the harmonic content was quite different too And best of all it doubled as a space heater and night light...
December 5, 200718 yr The Svetlana's work much, much better as a night light, thoriated tungsten glows so much better than zinc
December 5, 200718 yr actually 0.2% is really high..... i was thinking in the 0.05 range.... did you mean 0.02?In your install you are going to be lucky to differentiate 5-10%
December 5, 200718 yr actually 0.2% is really high..... i was thinking in the 0.05 range.... did you mean 0.02?The manual for the SX 2-channel amps say 0.02 @ 4ohm stereo, and 0.2 at 2ohm stereoThe SX 4channel amps don't go below 1% THD
