Posted December 5, 200718 yr need your guys help this set- ups goin in my blazer im looking at the 2 15 btl fully loaded are the 2 15 sound splinter RL-s15. this would be for a daily driver and if you guys could help with a good amp for these thank you
December 5, 200718 yr Two fully loaded BTLs should be able to handle 2 Sundown SAZ-3000D's if properly setup.
December 5, 200718 yr Admin The BTL and RL-s are two entirely different drivers by design. The BTL being a high power high output driver. The RL-s being a long throw high power SQ driver. You have the give some idea as to what sound you want or performance you are going for. People have this perception that if they want loud they need a fully loaded BTL when they don't have the power or install for a BTL, the BL gets over looked.
December 5, 200718 yr The BTL and RL-s are two entirely different drivers by design. The BTL being a high power high output driver. The RL-s being a long throw high power SQ driver. You have the give some idea as to what sound you want or performance you are going for. People have this perception that if they want loud they need a fully loaded BTL when they don't have the power or install for a BTL, the BL gets over looked.I agree. I think the BL falls to the side too often.I think I know why.People like to say they have a fully loaded BTL.Sounds cool, if you are in the know. It's like subwoofer 133+I was highly tempted by the BL, but in the end I want way more SQ than it can offer, and I'll do a Ground pounder later.... besides I need to spend all cash on a deck mids highs dampening, and marble floors first.To the OP though, check out the BL or even the the Icon. Those are sexay looking woofs to me. Edited December 5, 200718 yr by dem beats
December 5, 200718 yr Author im looking for a sub to hit hard low deep tones and and at the same time i want a sub that goin to sound good thank you could i get some suggestions!!!!!
December 5, 200718 yr If you're interested in Fi, the Q line seems like it fits the bill perfectly...wouldn't recommend the BTL for that.
December 20, 200718 yr i have a pair of fully loaded BL's minus the extream lead, and with a goliath and a tuned box there tha best subs i have had, and i have ran alot of subs, im currently awaiting a sundown 3000 but from what i have read, with a stout charging system, that amp should be ALMOST a perfect match, one problem i had was the fi dual 1's are not 1 there .70 per coil, so when wired to be 1 ohm at the amp the ohm load is only .70 not 1 ohm, so that why the sundown is best for me, because the sundown although not warrenteed is that how you spell it? anyway from what i understand the sundown will run down to .35 ohms, and still play, im guessing for brups but im a daily bass head, so what ever
