Posted December 6, 200717 yr Im deciding between 2 fi Q 12s sealed, or 2 15 Qs sealed... If I went with the 15s I would be a little under the space per sub, but which do you guys think would be better to get?
December 6, 200717 yr Author What kind of power and room do you have to work with?Thanks!-NickIll be using ahttp://www.woofersetc.com/index.cfm?fuseac...;product_id=524to power both the subs, so I have good power. And room... I dont have dimensions, but you can get an idea from herehttp://www.subthump.com/acamarowell.htmabout 1.0 cu ft each with 2 12's sealed and around 1.6 with 2 15's sealed.
December 6, 200717 yr 15s would be louder overall and you could lower the QTC some with about 1 lb of poly fill per cuft of enclosure... but the qtc still is too high for my tastes. Little too punchy.12s in 1 cuft per would work well. That definitely is a solid amp that doesnt skimp on power. Probably about 1200W per sub. Should make for a very solid system.Thanks,Scott
December 7, 200717 yr Go for the 2 12"... They will make for an easier install and will actually have proper enclosure... If I remember correctly, Camaro's don't have room for a box the right size for a 15 to mount on them unless you have them tilted forewards like in those pics which would be a lot harder to make a box for than just 2 12" facing up....
December 7, 200717 yr Author Go for the 2 12"... They will make for an easier install and will actually have proper enclosure... If I remember correctly, Camaro's don't have room for a box the right size for a 15 to mount on them unless you have them tilted forewards like in those pics which would be a lot harder to make a box for than just 2 12" facing up....yeah ive decided on the 2 12s, will be ordering in 2 weeks
December 8, 200717 yr Probably for the best... I know a chick who has a 12 in that little hole in the back of her camaro and there is not much room on the edge of the woofer so i dont think it would have been easy to make a box for a 15... And the work to do it would probably not be worth it since they would still be in too small of a box...
