Posted December 11, 200717 yr Do you think 2 loaded BTL's with daily option will work with 4 SAZ-3000D's in a SPL only setup (burp). This will be a 16 volt system and box after sub and port displacement will be 8.75 cubic feet tuned to 50hz. If not what subs.
December 12, 200717 yr If you're only burping it, I'd forgo the daily option and get the tighter tolerance coil assembly...
December 12, 200717 yr Dont want loaded BTL's for SPL...The Hixmax coil hurts it numbers wise..as does the cooling..
December 12, 200717 yr Author Subs are 15' BTL's with Pole Chamfer, Dual 1ohm voice coils, HiXmcoil, Daily, 3rd magnet and Universal setup. Can this be changed to SPl and no HiXmcoil, dual 1's and Universal with Pole Chamfer. Want it for best possible SPl set up. What would recone cost shiped to Glendive, Mt. 59330. Edited December 12, 200717 yr by bdufner
December 12, 200717 yr It's not a recone man it's the motor itself...there's a good amount of steel taken out of the inside of the motors for cooling, that generally have adverse effects on SPL due to less motor strength...Thanks!-Nick
