Posted December 16, 200718 yr I just purchased a Rockford Fosgate Power 1000. I will be purchasing a Jeep Wrangler unlimited and the amp and 1 sub will go in.Question: What fi 10 sub would work best with the 1000.I just would like one sub sealed or ported, still have to leave room for the wife and kid. http://ampguts.realmofexcursion.com/Rockfo...000_25_To_LIFE/Thanks
December 16, 200718 yr Either the Q or the SSD would be fine with the power you'll have.If you're looking to save space, go with the Q in a sealed box.
December 17, 200718 yr Fi are good drivers. Each driver has its own benefits AND drawbacks.It is impossible to make a driver that is perfect for all situations and many times have a give and take relationship. For instance, the BL driver, in direct comparison to ALL Q drivers of the same size can not play as low (some dip s*** kid is going to say how his buddies BL or BTL
