Posted December 19, 200717 yr my buddy is wanting eather a 15in fi bl or and fi Qhe can't decide which on will hit harder.
December 19, 200717 yr How much power, space, and what does he listen to?Qs are clean and deep and are a little more SQ oriented. BLs hit harder and are built to take a little more abuse...
December 19, 200717 yr Author How much power, space, and what does he listen to?Qs are clean and deep and are a little more SQ oriented. BLs hit harder and are built to take a little more abuse...he listens to rap.which one will hit deeper. hooked up to a 1200 brutusat 1ohmthe fi will be at 1 ohm also
December 19, 200717 yr Qs will play deeper in the proper box. For a 1 Ohm stable amp, you will need to order the D2 sub. Wired in parallel it will yield a 1 Ohm load for the amp.Thanks,Scott
December 19, 200717 yr Author Qs will play deeper in the proper box. For a 1 Ohm stable amp, you will need to order the D2 sub. Wired in parallel it will yield a 1 Ohm load for the amp.Thanks,Scottthanks.
December 19, 200717 yr Author Qs will play deeper in the proper box. For a 1 Ohm stable amp, you will need to order the D2 sub. Wired in parallel it will yield a 1 Ohm load for the amp.Thanks,Scottthanks.one mor question.what does the Bp power do?add more watts?and would it sound better in a ported or sealed box.thanks. Edited December 19, 200717 yr by mdizzle5472
