Posted December 22, 200718 yr Does anybody have some pics of a btl or bl motor with the cooling and without it?? i have alway wondered what the difference is in the motor thanks.
December 22, 200718 yr Sorry man..Only difference is there are cooling channels machined in, if they aren't in there then it's just a plain piece of round stock.Thanks!
December 23, 200718 yr Author Sorry man..Only difference is there are cooling channels machined in, if they aren't in there then it's just a plain piece of round stock.Thanks!u mean the holes that are around the motor wich allows u to see the coil inside the motor?? what about daily and spl whats the difference in the sub material?
December 23, 200718 yr I believe the holes are in the bottom of the motor, around the hole in the center of the motor.
December 23, 200718 yr Sorry man..Only difference is there are cooling channels machined in, if they aren't in there then it's just a plain piece of round stock.Thanks!u mean the holes that are around the motor wich allows u to see the coil inside the motor?? what about daily and spl whats the difference in the sub material?Difference in spl gap and daily gap is the top plate on the SPL gap is much tighter...There are no holes in the bottom of the motor, the inside of the motor pole/top plate is machined for cooling purposes..if it doesn't have cooling then it is just a smooth piece of 3" solid steel stock...Thanks!
